Im trying to make a burndown chart on ignition, but can find any suitable component. I make a workaround using a regular chart and a white stacked coloumn, but that have issues aswell. Box and whiskers might be a solution, but the median is bugging me. Anyone who found a good way og making one, similar to this
Is it because the gridlines are hidden by the white bars? If so, you should be able to adjust the opacity of the color.
That helped on the looks, thx. I was just wondering if there were a more suitable solution that didnt require alot og math and tag binding to where the next bar should start/stop, but its doable with this.
If you can post a sample raw dataset and an end result dataset, I can probably help out with optimizing what you have.
Was also going to say that if this is coming from a database, we may be able to tweak the query to just give you the end result dataset. Let the db do the heavy lifting.
