In 7.9.5 if you place a button component on the screen and uncheck then recheck the “Fill Area” property, the fill no longer is contained by the button border. I haven’t found a way to fix this other than placing a new button on the screen. Is there any way around this?
In the screenshot below are two buttons that were dropped on the window from the component palette. The button on the left has had the “Fill Area” property unchecked and then rechecked. You can see the white-ish background color that now “bleeds out” of the button border.
