Hi guys,
The button script (thanks to adamaustin
) that worked perfectly in V7.6 now fails to work in V7.7
from java.awt import Frame
win = system.gui.getParentWindow(event)
print "got it"
parent = win
while parent is not None:
win = parent
parent = win.getParent()
print ("got another" if parent is not None else "TOP")
win.setState(Frame.ICONIFIED)
The Error that comes up
[quote]Traceback (most recent call last):
File “event:mousePressed”, line 7, in
java.lang.ClassCastException: com.inductiveautomation.ignition.client.launch.BootstrapSwingFS cannot be cast to javax.swing.JComponent
at com.inductiveautomation.factorypmi.application.script.PyComponentWrapper.hasCustomFunction(PyComponentWrapper.java:186)
at com.inductiveautomation.factorypmi.application.script.PyComponentWrapper.__findattr_ex__(PyComponentWrapper.java:113)
at org.python.core.PyObject.__getattr__(PyObject.java:923)
at org.python.pycode._pyx9.f$0(<event:mousePressed>:9)
at org.python.pycode._pyx9.call_function(<event:mousePressed>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:568)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:168)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:265)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy21.mousePressed(Unknown Source)
at java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
java.lang.ClassCastException: java.lang.ClassCastException: com.inductiveautomation.ignition.client.launch.BootstrapSwingFS cannot be cast to javax.swing.JComponent
at org.python.core.Py.JavaError(Py.java:495)
at org.python.core.PyTableCode.call(PyTableCode.java:168)
Caused by: java.lang.ClassCastException: com.inductiveautomation.ignition.client.launch.BootstrapSwingFS cannot be cast to javax.swing.JComponent
at com.inductiveautomation.factorypmi.application.script.PyComponentWrapper.findattr_ex(PyComponentWrapper.java:113)
at org.python.core.PyObject.getattr(PyObject.java:923)
at org.python.pycode._pyx9.f$0(event:mousePressed:9)
at org.python.pycode._pyx9.call_function(event:mousePressed)
… 39 more
Ignition v7.7.0 (b2014071516)
Java: Oracle Corporation 1.7.0_67
[/quote]
Not sure if its a Java 8 issue?? ![]()
Any guidance is appreciated.
Cheers
