Buy theme, or get the HMI designed
Hi
In perspecitve, are the any ready made themes that will help the HMI look modern, that can be bought or downloaded somewhere?
Visual design is not my strong side and it would be good to have some idea to use as a base.
Thinking if there are anything similar to Ignition that many html cms have, themes with a cerain look to get a good visual idea to use as a base.
You can checkout Ignition exchange:Ignition Exchange | Inductive Automation
While doing a fresh install of Ignition you will have an option to include Ignition Quick Start project , which can also be helpful.
