Is it possible to launch my project straight and to perform gateway check using system.util.getGatewayStatus in client startup script or a loading page instead of the usual gateway connection page done by ignition?
The reason why I need to do so is because during the ignition checking page for gateway connection, user may be able to click onto the configuration button at the bottom of the checking page, which will allow user to access the window.
FYI, I have already disable the window function and feature, (eventually also the window shortcuts on the keyboard) and boot ignition straight after the workstation has powered up.
