Bypass prompt to enter name when restoring backup with gwcmd
As the title states I’m looking for a way to bypass the user prompt when attempting to restore a gateway backup using the gwcmd command line tool
If you pass the -y or --promptyes flag, you won’t be prompted for a gateway name.
For Ignition 7.9.x, the -y flag might not be enough to avoid the prompt for gateway name. You can workaround it using the technique shown on L416 here.
Thanks Kevin! I actually came to close this one out since I found that exact same solution. Much appreciated!
