It seems that there are no tags available for the load factor for any certain device.
What about calculating the load factor for a device in Python?
How is the load factor calculated and what functions are available in Ignition to get the values needed for the calculation?
I would like to be able to send a warning that the load factor is over a certain percentage.
What are you referring to when you say load factor? Load on the gateway cpu/memory, the client session memory, or the client machine cpu/memory?
The load factor mentioned here in the documentation when you click on device details. https://docs.inductiveautomation.com/display/DOC80/Connections+-+Devices
I see, I missed the “device” part first go around. I won’t be much help on this one.
