Is it possible to create a python script and execute it via the command line as though it was executed in the script console?
For example, I would like to create a script that automatically configures my Sepasoft related information:
import system
enterprise = system.mes.loadMESObject("New Enterprise", "Enterprise")
enterprise.setName(ENTERPRISE_NAME)
enterprise.setActive(True)
enterprise.save()
Is there a way to run this script from the ignition command line? Using java and the jython jar directly unsurprisingly fails to import system.
ignition@c245a9a8fd0c:/usr/local/bin/ignition$ /usr/local/bin/ignition/lib/runtime/jre-aarch64/bin/java -Dpython.import.site=false -jar lib/core/common/jython-ia-2.7.2.3.jar setup_equipment.py
File "setup_equipment.py", line 1, in <module>
import system
ImportError: No module named system
