Call file .bat from scedulated script python
Goodmorning,
I need to create a script schedule, inside this script I need to call a batch file.
I try to use the python module subprocess, but the bat script was never execute.
I try to use two different code:
======FIRST======
import subprocess
subprocess.call([r’D:\Script\Call_SFTP_KOJ002.bat’], shell=True)
======SECOND======
from subprocess import Popen
p = Popen([“D:/Script/Call_SFTP_KOJ002.bat”], shell=True)
p.wait
stdout, stderr = p.communicate()
print p.returncode
I prefer the second one because I can see if the command will be execute and is possible to write the result in log file
Can somebody help me?
Carlo
Hi, nobody reply me.
I solve the problem and share the solution:
I use this code for call file bat by python script
p = Popen(args=[“file.bat”], cwd=“D:\Script”, shell=True)
p.wait
error = p.returncode
return error
Bye
simple method
system.util.execute(["C:\\CSV\\Tools\\MoveFiles.bat"])
https://docs.inductiveautomation.com/display/DOC79/system.util.execute
