Hi, I am new to ignition. So, my question belongs to the basic level. I want to know that how we can use the function in Tabel Customizer where we can change field value depending on value.
I have created a string-type field and now want to use every bit as a separated flag instead of creating a separate field for every flag.
No, the table customizer yields a static configuration.
If you need dynamic formatting, you need to use a Power Table's configureCell component method.
Thanks, Pturmel,
I appreciate your quick and solution solution-oriented reply.
