Calling a PostgreSQL stored procedure in a transaction group fails
I have a transaction group that is calling a PostrgreSQL stored procedure that is getting an error message:
Error during group execution. Error registering parameter 'datetime'. Verify that the parameter name and type are correct. Method org.postgresql.jdbc.PgCallableStatement.setObject(String,Object,int) is not yet implemented.
The definition of the stored procedure:
create or replace procedure sp_record_kpi (
serialNo int
, kpiId int
, dateTime timestamptz
, sampleValue float
I've modified the translator to use timestamptz for the the Datetime mapping.
When I call the stored procedure in python (using runPrepUpdate), the call works flawlessly. Any help would be greatly appreciated. Thanks.
Your column name has a capital "T", probably to avoid clashing with the reserved word "datetime". If you use anything but lower case in PostgreSQL identifiers (table names, column names, schema names, etc.), you must quote the name with double quotes.
Huh. I don't really understand how Postgres' driver works at all, to be honest.
PgCallableStatement throws the 'not yet implemented' error for any of the 'setX' methods:
But that's how they say to use it in their documentation:
https://jdbc.postgresql.org/documentation/callproc/
It doesn't really seem to matter what I do, I'm receiving that same message. I created a test procedure:
create or replace procedure sp_test (
string_data varchar(255)
as $$
begin
return;
end; $$
language plpgsql;
and get the same error when the transaction group executes
That's exactly what I'm finding during my tests.
Try using parameter numbers instead of names.
Do you mean this?
After about an hour on the phone with tech support, I was told that there's a known bug with executing a stored procedure with named parameters in Postgresql from a transaction group. The developers are unable to fix the issue. Ugh.
i still have this problem in ignition 8.1.50.. is there any solution ?
I opened a ticket and was told that there were no plans to add support for stored procedures in 8.1. Maybe it’s available in 8.3? I ended up creating triggers to do the work. Not ideal.
–steve
I saw this statement from another forum:
”Unfortunately, using the parameter names is not a feature supported by the implementation of the JDBC 4 driver for the PostgreSQL database.
However, you can still continue to use an integer (variable or literal) to indicate the position of the parameter.”
So, if you have the following SP,
CREATE FUNCTION sample(
VARCHAR(50),
TIMESTAMP
you’d want to reference to VARCHAR(50) as 1
and timestamp as 2 in the Designer.
Thanks piege. I will keep this in mind next time I try to execute stored procedures against a PostgreSQL database.
