How can I call a project script from a tag value change event script ignition version 7.9.
project script file= utility
project function= insert
Tag Value change event script using-
project.utility.insert()
Tags are global resources, they don’t belong to a project.
In 7.9 and prior you can only call scripts in the global namespace from a tag change script.
In 8.0+ you can only call scripts in whatever is defined as the Gateway Scripting Project from a tag change script.
If you absolutely need to do this from within a project, use a tag change gateway event in the project instead of the event script on the tag.
