Calling Schedule Gateway Script from Button as well
Hi Team,
Currently using ignition vision 8.1.17.
I currently got schedule script which get executed on set time every day. Is it possible to call that script from client using trigger of button?
Or is there any other way to call gateway schedule script to be trigger based on button if required?
thanks in advanced.
You can create a single script that can then be called from either the gateway scheduled script or the button script.
Thanks Kathy for your quick response. Is there any documentation i can refer to create this single script?
https://docs.inductiveautomation.com/display/DOC81/Project+Library
