Hi Board-members,
We have recently got the request to integrate cognex cameras into the ignition system.
Does any one have any experience with this.
What they want to be able to do is use ignition as a gateway to download the batch data to the camera’s and label printers.
There are so many cameras on the line that it is not feasible to use the normal software packages included with these cameras.
I see that the cognex cameras support ethernet/ip and modbusTCP.
So i presume ignition should be able to communicate with these.
The other option would be the ActiveX component route, which is not a good idea as i presume the ActiveX module is only loaded once a client is open.
Any opinions and directions welcome
Regards
Sascha Hlubek
