Can a Expression Tag Reference itself
I have a tag1 and a tag_result.
I only want to save the first positive value that I encounter from tag1.
Like this:
tag1 tag_result
-100 0
-200 0
100 100
200 100
-100 0
200 200
300 200
200 200
100 200
-200 0
I tried to do this:
1 if(
2 	{[.]tag1} < 0,
3 	0,
4 	if(
5 		{[.]tag_result} > 0,  # already a value saved
6 		{[.]tag_result},  # no change
7 		{[.]tag1}
8 	)
9 )
However, line 6 is given a error_confg.
Any idea of why this could be?
As a temporal solution I'm using a script when ValueChanged in tag1
Thanks in advance!
Maybe try
    if (
        self < 0,  # Use 'self' instead of tag1
        0,
        if (
            {[.]tag_result} > 0,  # Already a value saved
            {[.]tag_result},  # No change
            self  # Use 'self' instead of tag1
Doesn't work. We are at expression language so is not the same as python sadly
Expression can't write to istelf. Your tag script is the best solution.
If you have a lot of those, however, consider using a gateway tag change script.
