Hi I am trying to use this script to filter the number of alarms depending on what the Client Tag name is.
runScript(“system.alert.queryAlertStatus(” +
“activeAndAcked=” + toInt({Root Container.Alarms.activeAndAcked}) + “,” +
“activeAndUnacked=” + toInt({Root Container.Alarms.activeAndUnacked}) + “,” +
“clearAndAcked=” + toInt({Root Container.Alarms.clearAndAcked}) + “,” +
“clearAndUnacked=” + toInt({Root Container.Alarms.clearAndUnacked}) + “,”+ “displayPath=” + toString({[Client]SITE_NAME}) +").rowCount", 1000)
I am getting this error
a java.lang.Exception: Error executing expression binding on
Navigation.Root Container.Alarms.alarms
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:82)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.childInteractionUpdated(ExpressionPropertyAdapter.java:50)
at com.inductiveautomation.ignition.common.expressions.TagListener.tagChanged(TagListener.java:74)
at com.inductiveautomation.factorypmi.application.sqltags.project.ProjectTagManager.subscribe(ProjectTagManager.java:360)
at com.inductiveautomation.ignition.client.sqltags.impl.ClientTagManagerImpl.subscribe(ClientTagManagerImpl.java:341)
at com.inductiveautomation.ignition.common.expressions.TagListener.startup(TagListener.java:86)
at com.inductiveautomation.ignition.common.expressions.BoundTagExpression.startup(BoundTagExpression.java:91)
at com.inductiveautomation.ignition.common.expressions.AbstractExpression.startup(AbstractExpression.java:73)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.startup(FunctionExpression.java:64)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.startup(ExpressionPropertyAdapter.java:101)
at com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController.setPropertyAdapter(DefaultInteractionController.java:196)
at com.inductiveautomation.factorypmi.designer.property.configurators.ExpressionConfigurator.bind(ExpressionConfigurator.java:264)
at com.inductiveautomation.factorypmi.designer.property.configurators.ExpressionConfigurator.tryCommit(ExpressionConfigurator.java:212)
at com.inductiveautomation.factorypmi.designer.property.configurators.ConfiguratorMultiplexor$EditorParent.tryCommit(ConfiguratorMultiplexor.java:206)
at com.inductiveautomation.factorypmi.designer.property.configurators.ConfiguratorMultiplexor.tryCommit(ConfiguratorMultiplexor.java:331)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.doOK(DynamicOptsDialog.java:117)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.access$000(DynamicOptsDialog.java:43)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog$1.actionPerformed(DynamicOptsDialog.java:83)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$2.run(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog$3.run(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at java.awt.Window.setVisible(Unknown Source)
at java.awt.Dialog.setVisible(Unknown Source)
at com.inductiveautomation.factorypmi.designer.property.configurators.DynamicOptsDialog.showDialog(DynamicOptsDialog.java:185)
at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.openBindingDialog(VisionDesignerImpl.java:759)
at com.inductiveautomation.factorypmi.designer.property.editors.bb.DynamicOptionsButton.actionPerformed(DynamicOptionsButton.java:36)
at com.jidesoft.plaf.basic.BasicJideButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at javax.swing.plaf.basic.BasicTableUI$Handler.repostEvent(Unknown Source)
at javax.swing.plaf.basic.BasicTableUI$Handler.mouseReleased(Unknown Source)
at com.jidesoft.swing.DelegateMouseInputListener.mouseReleased(Unknown Source)
at com.jidesoft.grid.TreeTable$DelegateExpandMouseInputListener.mouseReleased(Unknown Source)
Caused by: com.inductiveautomation.ignition.common.expressions.ExpressionException: Error parsing script for runScript() expression: SyntaxError: (“mismatched input ‘WWTW’ expecting RPAREN”, (‘expression:runScript’, 1, 133, ‘__RESULT = system.alert.queryAlertStatus(activeAndAcked=1,activeAndUnacked=1,clearAndAcked=0,clearAndUnacked=1,displayPath=BELTURBET WWTW).rowCount\n’))
at com.inductiveautomation.ignition.common.expressions.functions.ScriptFunction.execute(ScriptFunction.java:44)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.execute(FunctionExpression.java:69)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:73)
... 117 more
Caused by: SyntaxError: (“mismatched input ‘WWTW’ expecting RPAREN”, (‘expression:runScript’, 1, 133, ‘__RESULT = system.alert.queryAlertStatus(activeAndAcked=1,activeAndUnacked=1,clearAndAcked=0,clearAndUnacked=1,displayPath=BELTURBET WWTW).rowCount\n’))
at org.python.core.PyException.fillInStackTrace(PyException.java:70)
at java.lang.Throwable.<init>(Throwable.java:181)
at java.lang.Exception.<init>(Unknown Source)
at java.lang.RuntimeException.<init>(Unknown Source)
at org.python.core.PyException.<init>(PyException.java:46)
at org.python.core.PyException.<init>(PyException.java:43)
at org.python.core.PyException.<init>(PyException.java:39)
at org.python.core.PySyntaxError.<init>(PySyntaxError.java:22)
at org.python.core.ParserFacade.fixParseError(ParserFacade.java:92)
at org.python.core.ParserFacade.parse(ParserFacade.java:199)
at org.python.core.Py.compile_flags(Py.java:1751)
at com.inductiveautomation.ignition.common.expressions.functions.ScriptFunction.execute(ScriptFunction.java:40)
... 119 more
Ignition v7.5.4 (b1206)
Java: Sun Microsystems Inc. 1.6.0_26
