Is there a way with the system.device.addDevice to chose which gateway a device is added to? We just moved to a scaled out arch and wanted to ease the adding of tags and devices.Thx, Jake
You will need to use the gateway messaging system for this to call the system.device.addDevice on the remote gateway. You may want to consolidate a couple of your most used messages into a single project that is common across the gateways to keep confusion down etc...
Sounds good, I'll mess with this as time permits. You rock.Thx jake
