Can the EP3C40Q240C8N be used for soft processor implementation like Nios II?
It's in the Cyclone III family, and coupled with this Quick Start sheet from Jameco, it appears that it would be compatible.
Outside of this, there's not anything more I can assist you with.
I was curious as to what brought you here, as this is pretty far afield from what this forum is about.
Then, I did a search of NIOS on the forum, which returns many hits mentioning the java.nio library.
If that's what brought your search here, then I'm sorry that this ends up as an otherwise dead-end.
