I have a gateway message handler to create PDF’s. It makes new folders and then creates a PDF report and puts it inside of one of those folders. Here are the relevant parts -
try:
new_folders.create.folder(destinationPath)
except OSError:
logger.info("folder already created")
pass
# ******* CREATE PDF QUOTE ******* #
try:
system.report.executeAndDistribute(path=reportPath, project="PSM4_Project", action="save", parameters=overRides, actionSettings=settings)
status = True
Message = "Successfully uploaded PDF!"
except:
logger.info("ERROR: ")
status = False
Message = Message + str(sys.exc_info()[0]) + " | " + str(sys.exc_info()[1])
logger.info("ERROR: " + str(Message))
logger.info('here 9')
project = "PSM4_Project"
logger.info('here 10')
messageHandler = "handleSaveQuoteResponse"
logger.info('here 11')
parameters = {'ClientSessionID': ClientSessionID, 'Message': Message}
logger.info('here 12')
results = system.util.sendMessage(project,messageHandler,parameters,scope="C")
Now I am able to make the folders with the new_folders.create.folder() script and that works. But then my system.report.executeAndDistribute failes, and then also the Message variable is always
“Successfully uploaded PDF!” even when the system.report.executeAndDistribute line fails which is confusing me as well, and then I get the error message sent to the client. So it seems like this gateway message handler is sending two messages back to the client, first with the message “Successfully uploaded PDF!” and then again with the sys.exc_info() from the except clause.
I turned on Trace for Reporting Module in the gateway logs and this is what I see
Data 23Mar2021 10:02:00 [projectName=PSM4_Project,reportPath=Quote_Time_Material 0] Could not create directory P:\Heerema\Hawthorne, NJ\L'Oreal - Clark\Filling Line 1 Kalix Service, 7098\Quotes\ in SaveAs Action Save File
java.io.IOException: Unable to create directory P:\Heerema\Hawthorne, NJ\L'Oreal - Clark\Filling Line 1 Kalix Service, 7098\Quotes
at org.apache.commons.io.FileUtils.forceMkdir(FileUtils.java:2211)
at com.inductiveautomation.reporting.gateway.actions.SaveFileReportAction.perform(SaveFileReportAction.java:91)
at com.inductiveautomation.reporting.gateway.actions.SaveFileReportAction.perform(SaveFileReportAction.java:148)
at com.inductiveautomation.reporting.gateway.scripting.GatewayScriptingFunctions.lambda$executeAndDistribute$1(GatewayScriptingFunctions.java:197)
at com.inductiveautomation.reporting.gateway.ReportingGatewayHook.executeReport(ReportingGatewayHook.java:305)
at com.inductiveautomation.reporting.gateway.scripting.GatewayScriptingFunctions.executeAndDistribute(GatewayScriptingFunctions.java:188)
at com.inductiveautomation.reporting.common.scripting.ReportScriptingFunctionsPyWrapper.executeAndDistribute(ReportScriptingFunctionsPyWrapper.java:77)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:524)
at org.python.core.PyObject.__call__(PyObject.java:413)
at org.python.pycode._pyx84.handleMessage$1(:124)
at org.python.pycode._pyx84.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
at org.python.core.PyFunction.function___call__(PyFunction.java:471)
at org.python.core.PyFunction.__call__(PyFunction.java:466)
at org.python.core.PyFunction.__call__(PyFunction.java:461)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:822)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:806)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:687)
at com.inductiveautomation.ignition.common.script.message.MessageHandlerRunnable.run(MessageHandlerRunnable.java:114)
It says it’s a file not found exception, but I don’t know how that’s possible since I just made the folder it’s supposed to go in, and if I copy/paste the folder location from the gateway and put it into a file explorer, it does exist.
After my client sends the gateway message, it gets two responses -
and then
Any insights would be helpful. Thanks
