Hi again I have a new problem now is in my Ignition Designer i can’t edit the pens of the Easy Chart when i want to configurate them, i clic on the button edit and doesn’t shows me the windows for editing the pens in the Easy Chart
Last time i had problems of not enough memory with the Ignition, I gave a solution to it ,thanks to Travis Cox, i wan’t using the easy chart but now that i want to use it, the problem i comment to you happens , please i will appreciate it to help me in this situation
Thanks to you
Carito
I looked the console in the Ignition designer in show me this:
INFO [DatasourceTagManager-AWT-EventQueue-0] Starting up polling tag manager, polling rate: 250ms
INFO [IgnitionDesigner-AWT-EventQueue-0] Starting module: Vision
INFO [IgnitionDesigner-AWT-EventQueue-0] Starting module: SQL Bridge
INFO [IgnitionDesigner-AWT-EventQueue-0] Starting module: Mobile
INFO [IgnitionDesigner-AWT-EventQueue-0] Starting module: Reporting
INFO [ReportingDesignerHook-AWT-EventQueue-0] Starting up Reporting Module. Mode: Activated
Initializing ReportMill (Build Date: May-27-05, Version 9.0, JVM 23.0-b21, User Administrator)
INFO [IgnitionDesigner-AWT-EventQueue-0] Starting module: Symbol Factory
INFO [DatasourceTagManager-SQLTags-TreeLoader-thread-1] Starting SQLTags polling.
Exception in thread “AWT-EventQueue-0” java.lang.NullPointerException
at com.inductiveautomation.factorypmi.designer.property.customizers.easychart.PenEditPanel.createTitledBorder(PenEditPanel.java:390)
at com.inductiveautomation.factorypmi.designer.property.customizers.easychart.PenEditPanel.initLayout(PenEditPanel.java:339)
at com.inductiveautomation.factorypmi.designer.property.customizers.easychart.PenEditPanel.(PenEditPanel.java:136)
at com.inductiveautomation.factorypmi.designer.property.customizers.EasyChartCustomizer$PenPanel$PenEditor.(EasyChartCustomizer.java:1150)
at com.inductiveautomation.factorypmi.designer.property.customizers.EasyChartCustomizer$PenPanel$PenEditor.editPen(EasyChartCustomizer.java:1134)
at com.inductiveautomation.factorypmi.designer.property.customizers.EasyChartCustomizer$PenPanel$EventHandler.actionPerformed(EasyChartCustomizer.java:886)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.WaitDispatchSupport$2.run(Unknown Source)
at java.awt.WaitDispatchSupport$4.run(Unknown Source)
at java.awt.WaitDispatchSupport.enter(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at java.awt.Window.setVisible(Unknown Source)
at java.awt.Dialog.setVisible(Unknown Source)
at com.inductiveautomation.factorypmi.designer.property.CustomizerDialog.setVisible(CustomizerDialog.java:153)
at com.inductiveautomation.factorypmi.designer.property.propertytable.PropertyTablePanel.handleCustomizerAction(PropertyTablePanel.java:229)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.handleDoubleClick(WindowWorkspace.java:1010)
at com.inductiveautomation.ignition.designer.designable.tools.SelectionTool.onDoubleClick(SelectionTool.java:524)
at com.inductiveautomation.ignition.designer.designable.DesignPanel$ToolMouseListener.onClick(DesignPanel.java:988)
at com.inductiveautomation.ignition.client.util.gui.CommonMouseAdapter.mouseReleased(CommonMouseAdapter.java:69)
