Hi, ,
I took a Numeric Label from the component palette, I put its tag into the numeric label, write the unit and etc , save the aplication, but when I put in the runtime form, the unit in the numeric label doesn’t seems.
My question is why is happening this? and what can I do to resolve it…
I will apreciatte your help…
Thanks very much!!
Note.-
I noted that when I close the design window, of course I commit the changes too, and when I open the window again, the units have dissapeared.
please help me…
and Thanks again…
When you drag a tag onto a component, it binds multiple properties. In this case, I suspect that the units property is bound to the tag’s Engineering Units property (Notice that the Units property is Bold, am right?)
You should either:
- Edit the tag’s engineering units instead of the label’s units field
OR
- Remove the binding on the units field so it doesn’t get overwritten when the window opens.
Ohh very good you were right, Units property was Bold, I took off the Binding and now the problem on the unit of the numeric label has gone.
Thanks very much!!!
Is there a way to setup what is bound when I drag a tag onto an item?
No, it is pre-configured based on the type of item. This is an area we are looking at for 7.4, however.
