Hi everyone,
I’m new to Ignition, and I’m running into an issue with SVG files in Perspective. Here’s the workflow I’ve tried:
- I used Inkscape to prepare my SVG—ungrouped all elements and assigned unique IDs so that I can edit each object (e.g. tanks, text labels).
- I exported as “Plain SVG” and then imported it into a Perspective View by dragging & dropping and choosing “Save and Link.”
- In Inkscape, I can select, move, and resize individual objects. However, once it’s in Perspective (Designer or Session), the SVG behaves as one single image—none of the IDs or individual paths are accessible.
My goal is to bind and edit individual SVG elements (for example, update the text inside a tank or change a valve color dynamically).
- Is there a way to import/edit an SVG so that each object remains separate in Perspective?
- Am I missing a specific component or workflow step?
- Are there any recommended modules or tools (e.g., the “Simple SVG Editor” project) I should install to achieve this?
Thanks in advance for your help!
