Can The Vision Launcher Launch applications without a Connection To The Gateway?
I'm assuming no, but just double checking with you guys...
We at the plant need a backup for an application incase the ignition server goes down, is there a way to have a vision application run without a connection to the vision server.
I don't believe it's possible to run the application without a connection. The application needs to be connected to read tags, and gather data so even if you could you wouldn't be reading any data.
You should look into setting up a redundant gateway see more here:
There's also the local client fallback for this scenario, but like redundancy it involves a second gateway: Local Client Fallback | Ignition User Manual
Thank you guys!
