We need View clients to communicate with scales through the pc serial port. We’re trying to avoid using serial/EtherNet adapters. The following (RXTX-2.1-7) code under #—WRITE— works great, but I can’t get the code under #—READ— to work. No errors, just doesn’t read it. I’m testing with a second pc running HyperTerminal. I’d really appreciate any suggestions - thanks.
[code]from gnu.io import CommPort, CommPortIdentifier, SerialPort
from java.io import FileDescriptor, IOException, InputStream, OutputStream
portIdentifier = CommPortIdentifier.getPortIdentifier(“COM5”)
if portIdentifier.isCurrentlyOwned():
print “Error: Port is currently in use”
else:
commPort = portIdentifier.open(“IgnView-SerialTest”, 2000)
if isinstance(commPort,SerialPort):
serialPort = commPort
serialPort.setSerialPortParams(9600, SerialPort.DATABITS_7, SerialPort.STOPBITS_1, SerialPort.PARITY_NONE)
#---WRITE---
outStr = serialPort.getOutputStream()
outStr.write("msg-out ")
#---READ---
numBytes = -5
readBuffer = " "
inStr = serialPort.getInputStream()
numBytes = inStr.read(readBuffer)
print numBytes
print readBuffer
print "done"
else:
print "Error: Only serial ports are handled by this example."
commPort.close()[/code]
I don’t think I can really help you with 3rd party libraries like RXTX, which I have no experience with. I’m curious, how did you get RXTX into our software?
From rxtx.qbang.org/wiki/index.php/In … or_Windows (files are attached)
[color=#0000FF]If you just want to run RXTX enabled programs, follow this procedure.
Identify your Java Runtime Environment’s folder. For version 1.6.0, this usually is c:\Program Files\Java\jre1.6.0_01\
Copy rxtxParallel.dll to c:\Program Files\Java\jre1.6.0_01\bin\
Copy rxtxSerial.dll to c:\Program Files\Java\jre1.6.0_01\bin\
Copy RXTXcomm.jar to c:\Program Files\Java\jre1.6.0_01\lib\ext[/color]
rxtx-2.1-7-bins-r2.jar.gz (589 KB)
Ok fair enough.
You’re still on your own with RXTX however as we can’t really support something we didn’t provide. But to give you a starting point - I’d say that you can’t use a string as a buffer like that - it doesn’t really make sense because strings are immutable.
InputStream.read is looking for a byte array. I tried
readBuffer = range(20) and readBuffer = zeros(20, ‘b’)
before I tried the string. No luck.
Well, I’m just shooting in the dark, but I google’d for creating a byte array in jython and came up with:
import jarray
bytearray = jarray.zeros(1024,'b')
I didn’t go beyond that (how to convert the jarray to different types, etc.), but hopefully that helps you get past your current block
I finally had time to play with this some more - got it to work with plain ol’ javax.comm.
My next challenge is to get javax.comm & associated files to automatically deploy to clients, since javax.comm is deprecated. I’ll start digging around the Ignition Module Developers forum and see if I can figure it out. I’d appreciate any pointers to start me in the right direction - thanks!
[code]from javax.comm import CommPort, CommPortIdentifier, SerialPort
#For this code to work:
#Copy javax.comm.properties (1KB, 8/12/1999) to c:\Program Files\Java\jre6\lib\
#Copy win32com.dll (28KB, 8/12/1999) to c:\Program Files\Java\jre6\bin\
#Copy comm.jar (28KB, 8/12/1999) to C:\Program Files\Java\jre6\lib\ext
#Add this to system environment variable CLASSPATH: ;C:\Program Files\Java\jre6\lib\ext\comm.jar
portIdentifier = CommPortIdentifier.getPortIdentifier(“COM1”)
else:
serialPort.setSerialPortParams(9600, SerialPort.DATABITS_8, SerialPort.STOPBITS_1, SerialPort.PARITY_NONE)
#---WRITE---
outStr.write("msg-out")
#---READ---
inChr = -1
buffer = ""
try:
inChr = inStr.read()
while ((inChr > -1) and (chr(inChr) != '\n')):
buffer = buffer + chr(inChr)
print buffer
except IOException, e:
e.printStackTrace()
commPort.close()
else:
print “Error: Only serial ports are handled by this example.”
commPort.close()
[/code]
Due to the nature of the java comm extension and how it has to be installed on each client machine, I don’t think you’re going to be able to automatically deploy it through Java Web Start, which is how our clients run.
