I’d like to show tooltips over a button indicating what it does. Is this possible?
Yes, all components in FactoryPMI have a property called “Mouseover Text”. Type in the tooltip message that you want here, and it will show when the user hovers his/her mouse cursor over the component.
Tip: Use HTML formatting if you need multi-line tooltips.
Hope this helps,
Keep in mind that the “Mouseover Text” property is bindable like most other properties in FactoryPMI. You can use this property for “dynamic tooltips” - one of Intouch 9.0s major new features. This will create a tooltip that displays live values for the operator.
Here’s an example of how that might work.
- Create a dynamic variable called temperature. Bind it to an SQL query so that it’s value is always the current tempurature.
- Bind the “mouseover text” property to the following expression (Carl’s recommendation):
"<html>Compressor 1<br>Current temp is:<b><font color='red'>" + {temperature} + "°</b></font></html>"
This would display the following tooltip:
[size=75]Compressor 1
Current temp is: [color=red]175°[/color][/size]
You can create color changes between green and red depending on the temp, and additional flexibility with FactoryPMI expression functions.
Wrong forum?
