Can you run a tag report via a script?
I've used this tag report to get a quick csv file dump of all tags in a given provider loads of times.
I was wondering if there's a way I could execute this from a script to get the report results returned as a dataset? From there I'm comfy with getting that saved to a file, just not seeing anything jump out that looks like it would let me execute a tag report that I had already set up.
Yes, use system.tag.query().
See:
You can even configure a report via the UI and then click a button to export it as a script:
Oh awesome, thank you both!! Feeling silly for not having seen the "copy as script" button hahaha
