Canary Security with Ignition
Hi
I'm just wondering if there is anything special, I need to do when reading Canary trends into Ignition Trend components when security in Canary is activated.
It was working fine before I activate security. Axiom works fine with the new security.
I did change the port in the Canary Ignition module to the default https.
I'm using the same logon and password which works for me in Axiom.
I got the security between Canary Historian / Axiom and Ignition working through the default secured port.
Happy to help if somebody needs assistance in the future.
Please summarize your solution for future readers... since you are apparently the local expert. :grinning:
Hi Carel would you be so kind to assist us? Which port did you use for HTTPS?
When Canary security is enabled, Ignition may require more than just changing the HTTPS port. Make sure Ignition trusts Canary’s SSL certificate, if it’s self-signed, you need to import it manually.
