java.lang.ClassCastException: Cannot coerce value ‘30.7’ into type: interface com.inductiveautomation.ignition.common.Dataset
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:1299)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.setQValue(AbstractPropertyAdapter.java:218)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.setQValue(SimpleBoundTagAdapter.java:248)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateValue(AbstractPropertyAdapter.java:259)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.notifyTagChanged(SimpleBoundTagAdapter.java:501)
at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.tagChanged(SimpleBoundTagAdapter.java:490)
at com.inductiveautomation.ignition.client.sqltags.impl.db.DatasourceTagManager$TagChangeListenerProxy.tagChanged(DatasourceTagManager.java:1075)
at com.inductiveautomation.ignition.client.sqltags.impl.ChangeNotifier.run(ChangeNotifier.java:38)
at com.inductiveautomation.ignition.client.sqltags.impl.db.BatchNotifier.run(BatchNotifier.java:77)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
Ignition v7.9.9 (b2018081621)
Java: Oracle Corporation 1.8.0_151
Above is the detailed error I am getting. I tried to by mistake add the tag to a line graph since then have been receiving this error. I have deleted the lin graph but the error persists. I am not sure where this tag is being forced , coerced in to a data set. Is there a way to find out? I really don’t to do a gateway restore on a running system. Just for this one tag.
Any Help would be appreciated
Thanks in advance.
