Cannot coerce value into type: interface java.util.Map
Version: 8.1.32 (b2023091211)
Error running action 'component.onActionPerformed' on Control@D/root/WriteButton: Traceback (most recent call last): File "function:runAction", line 3, in runAction at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:1596) at com.inductiveautomation.ignition.common.script.builtin.PyArgumentMap.coerce(PyArgumentMap.java:130) at com.inductiveautomation.ignition.common.script.builtin.PyArgumentMap.interpretPyArgs(PyArgumentMap.java:82) at com.inductiveautomation.ignition.common.script.builtin.PyArgumentMap.interpretPyArgs(PyArgumentMap.java:40) at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities.interpretWithOptionalProject(GatewayDBUtilities.java:487) at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities.runNamedQuery(GatewayDBUtilities.java:392) at jdk.internal.reflect.GeneratedMethodAccessor73.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) java.lang.ClassCastException: java.lang.ClassCastException: Cannot coerce value '73.5' into type: interface java.util.Map
com.inductiveautomation.ignition.common.script.JythonExecException
  File "<function:runAction>", line 3, in runAction
	at org.python.core.Py.JavaError(Py.java:547)
	at org.python.core.Py.JavaError(Py.java:538)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
	at org.python.core.PyObject.__call__(PyObject.java:477)
	at org.python.core.PyObject.__call__(PyObject.java:481)
	at org.python.pycode._pyx15.runAction$1(<function:runAction>:3)
	at org.python.pycode._pyx15.call_function(<function:runAction>)
	at org.python.core.PyTableCode.call(PyTableCode.java:173)
	at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
	at org.python.core.PyFunction.function___call__(PyFunction.java:474)
	at org.python.core.PyFunction.__call__(PyFunction.java:469)
	at org.python.core.PyFunction.__call__(PyFunction.java:464)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:847)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:829)
	at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:852)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:1010)
	at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$AutoRecompilingScriptFunction.invoke(ProjectScriptLifecycle.java:934)
	at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:158)
	at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:97)
	at com.inductiveautomation.perspective.gateway.action.ScriptAction.runAction(ScriptAction.java:74)
	at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.lambda$call$0(ActionCollection.java:263)
	at com.inductiveautomation.perspective.gateway.api.LoggingContext.mdc(LoggingContext.java:54)
	at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:252)
	at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:221)
	at com.inductiveautomation.perspective.gateway.threading.BlockingTaskQueue$TaskWrapper.run(BlockingTaskQueue.java:154)
	at com.inductiveautomation.perspective.gateway.threading.BlockingWork$BlockingWorkRunnable.run(BlockingWork.java:58)
Caused by: org.python.core.PyException
	... 32 more
Caused by: java.lang.ClassCastException
com.inductiveautomation.ignition.common.GenericTransferrableException: Cannot coerce value '73.5' into type: interface java.util.Map
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
	... 29 more
Ignition v8.1.32 (b2023091211)
Java: Azul Systems, Inc. 11.0.18
I have a button with an event trying to execute a named query "change setpoint". The query works and I'm sure the issue is passing the parameter to the query. This is what I've tried. It seems like I might need a type conversion or something. This should be really easy but I've wasted a lot of time figure it out. Any help would be appreciated.
def runAction(self, event):
	parameters  = {"param1": self.getSibling("NewSetpoint").props.value}
	system.db.runNamedQuery("change setpoint", parameters)
It looks like I've answered my own question. This was not real clear and a better error description would be nice. You have to match the name of the parameter in the event with the name of the parameter in the query. I'm used to passing by value in Java.
Probably should not be datatype = 'String'.
