Cannot create PoolableConnectionFactory (Communications link failure)
Hello everyone,
I am new to both SQL and Ignition and I am using Ignition V8.1.6 on a Windows10 64bit platform and I am using mysql-connector-java-8.0.25.
When I’m trying to configure a database for MySQL JDBC Driver, Connector/J, I get this error:
"Cannot create PoolableConnectionFactory (Communications link failure The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.)"
This is also the additional error message in the box:
" java.sql.SQLException: Cannot create PoolableConnectionFactory (Communications link failure
Caused by: com.mysql.cj.jdbc.exceptions.CommunicationsException: Communications link failure
Caused by: com.mysql.cj.exceptions.CJCommunicationsException: Communications link failure
Caused by: java.net.ConnectException: Connection refused: connect "
When I created my database I did not change any settings and I did not assign any username and password and only added a name for the database!
Does anyone know how can I fix this?
Thank you in advance for your help.
That means Ignition never even got to submit any username, as the database isn't listening. If the DB is on a separate machine, you need to configure MySQL to listen to more than just localhost.
After you fix that, you will certainly need to ensure Ignition is using a user name and password that exists in your database.
Thank you for your response! DB is not on a separate machine.
I got it working based on the information on the manual, I had to set up some extra things in my SQL workbench.
https://docs.inductiveautomation.com/display/DOC80/Installing+MySQL
Seems like the biggest aspects not covered in the ignition university connect to MySQL video is:
  1. why we must have the user name as root(explained in solution link)
  2. Setting up a scheme to be used directly to ignition.(explained in solution link)
I am curious for the certification will this be acceptable as a setup or is ignition requiring something else.
If you have a question about the certification test, you should email training @ inductiveautomation.com and ask.
