Cannot drag and drop OPC tags from the browser in ignition designer to the tag viewer nor delete tags from the tag viewer
I have an ignition server instance i am testing in trial mode and i can't seem to add or remove tags to/from the tag viewer by deleting them manually or dragging and dropping them from the OPC browser.
The nature of the connection is that i originally established the OPC connection between a codesys PLC and an instance of ignition edge running on the PLC. Then, Iallowed an incoming connection from ignition gateway to ignition edge and the configured OPC tags showed up in my ignition designer session.
My question is will i have to update, add or remove tags in ignition edge directly? Can i not add or remove tags in the tag viewer of designer because the OPC connection actually exists between the edge instance and the codesys instance?
Correct
