version: '2.4'
services:
ignition:
build:
context: ignition
args:
IGNITION_VERSION: 8.3.1
ports:
- 80:8088
- 443:8043
- 8060:8060
volumes:
- ignition-data:/usr/local/bin/ignition/data
cap_add:
- SYS_RAWIO
- CAP_NET_BIND_SERVICE
- CAP_NET_RAW
environment:
- ACCEPT_IGNITION_EULA=Y
- IGNITION_EDITION=standard
- TZ=America/Chicago
- GATEWAY_MODULES_ENABLED=com.inductiveautomation.opcua.drivers.ablegacy,com.inductiveautomation.eam,com.inductiveautomation.opcua.drivers.logix,com.inductiveautomation.opcua,com.inductiveautomation.symbol-factory,com.inductiveautomation.opcua.drivers.tcpudp,com.inductiveautomation.vision,web-browser,com.inductiveautomation.historian,com.inductiveautomation.perspective,com.inductiveautomation.historian.sql
- DISABLE_QUICKSTART=true
- GATEWAY_ADMIN_USERNAME=admin
- GATEWAY_ADMIN_PASSWORD=password
command: >
-m 4096
-- gateway.resolveHostNames=true
-Dignition.license.leased-activation-terminate-sessions-on-shutdown=true
volumes:
ignition-data:
I am having an issue with enabling the historian core for 8.3.x in a docker environment. I have com.inductiveautomation.historian added for the gateway_modules_enabled. When I click on enable module
I get the following error message:
I downloaded the module from the inductive website, restarted the gateway, and I still get the same error. Any help would be greatly appreciated.
