I’m trying to build a module with an RPC Call. I couldn’t get it to work, so I tryied making a minimal example starting from a fresh project.
I followed the SDK docs for the biggest part, with two exceptions:
- The
getRPCHandleroverride on the GatewayHook now seems to need a string as second argument - I replaced the reference to
ModuleMeta.MODULE_IDwith"org.example.ModuleRPCImpl", which is the path to the implementing class.
I also made the method available to the scripting side as system.rpc.getGreeting, so I can test it easily. However, whenever I that method, I see the following errors:
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Module "org.example.ModuleRPCImpl" not found.
java.lang.IllegalArgumentException: Module "org.example.ModuleRPCImpl" not found.
I also treid with "org.example" as module id, but it gave a similar error "org.example" not found.
Full error stack:
Java Traceback:
File "<input>", line 1, in <module>
at com.sun.proxy.$Proxy61.getGreeting(Unknown Source)
at org.example.designer.RPCCaller.getGreeting(RPCCaller.java:10)
java.lang.reflect.UndeclaredThrowableException: java.lang.reflect.UndeclaredThrowableException
at org.python.core.Py.JavaError(Py.java:552)
at org.python.core.Py.JavaError(Py.java:543)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:520)
at org.python.core.PyObject.__call__(PyObject.java:480)
at org.python.core.PyObject.__call__(PyObject.java:484)
at org.python.pycode._pyx6.f$0(<input>:1)
at org.python.pycode._pyx6.call_function(<input>)
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.Py.runCode(Py.java:1614)
at org.python.core.Py.exec(Py.java:1658)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:131)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:605)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:593)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.reflect.UndeclaredThrowableException
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
... 19 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Module "org.example.ModuleRPCImpl" not found.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:339)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:313)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:266)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.moduleInvokeSafe(GatewayInterface.java:878)
at com.inductiveautomation.ignition.client.gateway_interface.ModuleRPCFactory$DynamicRPCHandler.invoke(ModuleRPCFactory.java:53)
... 26 more
Caused by: java.lang.IllegalArgumentException: Module "org.example.ModuleRPCImpl" not found.
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.ModuleInvoke.invoke(ModuleInvoke.java:68)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:411)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsyncServlet.service(ServletHolder.java:1391)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:760)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:547)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:500)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938)
at java.lang.Thread.run(null)
For anyone interested, here is the complete code of that example, including modl file under the build target.
TestProject2.zip (65.2 KB)
It seems like a basic thing to do, but I can’t get it right. I’m trying it on 8.0.10 at the moment.
