Cannot find database connection - name cannot be null
We are using a system.db.runPrepQuery in a UDT and are getting the following error when our tag event is being fired:
com.inductiveautomation.ignition.common.script.JythonExecException: java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepQuery( select top 1 DowntimeOngoingId ,MachineName ,SCWStatus ,FirstName ,LastName ,EmployeeId from [downtime_ongoing] where MachineName = ? and SCWStatus is not null and ClosedAt is null , , [ZZTest], )
Caused by: java.lang.IllegalArgumentException: Cannot find database connection - name cannot be null.
From what we understand, if you exclude the database argument it should use the project default as stated in the documentation:
String database - The name of the database connection to execute against. If omitted or "", the project's default database connection will be used. [optional]
Is this not the case when using system.db.runPrepQuery in a UDT or are we hitting a bug?
Tags don’t belong to any project. You have to include the database connection name.
@pturmel
I would think that tags get executed in the context of the project that is calling them? That would be a pretty be oversight in the documentation if that is the case.
Tag events are initiated by the tag itself. There’s no project calling them.
Thank you, however that’s ridiculous… The documentation needs to be updated in order to mention this as a warning… it caused us some real headaches.
@cmallonee
Yeah, it sure is. Normally we have a separate panel for gateway scoped syntax, specifically for cases like this. I updated the page for runPrepUpdate, but I'll take a look at the adjacent functions to see if there are any other offenders (I see a few). Thanks for mentioning the issue.
