hi, I write to you because I am having a problem with the system.db.runPrepUpdate script :
system.db.runPrepUpdate(“INSERT INTO test_cel(nombre,edad) VALUES(?,?)”,[‘Carolina’,31])
I don’t understand why it says me Invalid object name ‘test_cel’, this table exists and the name is correct.
File “event:actionPerformed”, line 1, in
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO test_cel(nombre,edad) VALUES(?,?), [Carolina, 27], , , false, false)
caused by Exception: Error executing system.db.runPrepUpdate(INSERT INTO test_cel(nombre,edad) VALUES(?,?), [Carolina, 27], , , false, false)
caused by GatewayException: SQL error for "INSERT INTO test_cel(nombre,edad) VALUES(?,?)": Invalid object name 'test_cel'.
caused by SQLServerException: Invalid object name 'test_cel'.
Ignition v7.6.3 (b2013090513)
Java: Oracle Corporation 1.7.0_03
Please help me to give a solution to this.
Thanks and Regards
Carito
