Cannot invoke java.lang.Boolean.booleanValue() on isCellEditable?
Using ignition Vision 8.1.47 with a power table.
Getting a error I haven’t experienced before on the isCellEditable extension function. I only want a subset of columns editable (any row) and if the tables root container custom property editable (which is a bool) is True then we are good to go. Put in some print statements for testing. This is throwing me the following output -
EDITABLE_COLUMNS = ['LIN', 'LOX', 'PLAR','CLAR','weightSource']
def isCellEditable(self, rowIndex, colIndex, colName, value):
	Only the product and weight source columns are editable, any row.
	print colName in EDITABLE_COLUMNS
	print self.parent.editable
	return colName in EDITABLE_COLUMNS and self.parent.editable
This is giving me the following output -
True
True
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException: Cannot invoke "java.lang.Boolean.booleanValue()" because the return value of "com.inductiveautomation.vision.api.client.components.model.ExtensionFunction.invoke(com.inductiveautomation.vision.api.client.components.model.ExtensibleComponent, com.inductiveautomation.ignition.common.util.LoggerEx, String, java.lang.Class, Object, Object[])" is null
	at com.inductiveautomation.factorypmi.application.components.VisionAdvancedTable$Model.isCellEditable(VisionAdvancedTable.java:1789)
	at com.jidesoft.grid.TableModelWrapperImpl.isCellEditable(Unknown Source)
	at com.jidesoft.grid.DefaultTableModelWrapper.isCellEditable(Unknown Source)
	at java.desktop/javax.swing.JTable.isCellEditable(Unknown Source)
	at com.jidesoft.grid.JideTable.editCellAt(Unknown Source)
	at com.jidesoft.grid.CellSpanTable.editCellAt(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicTableUI$Handler.adjustSelection(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicTableUI$Handler.mousePressed(Unknown Source)
	at com.jidesoft.swing.DelegateMouseInputListener.mousePressed(Unknown Source)
	at java.desktop/java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
	at com.jidesoft.docking.DockingUtils.a(Unknown Source)
	at com.jidesoft.docking.DefaultDockingManager.handleEvent(Unknown Source)
	at com.jidesoft.docking.DefaultDockingManager$a3.eventDispatched(Unknown Source)
	at java.desktop/java.awt.Toolkit$SelectiveAWTEventListener.eventDispatched(Unknown Source)
	at java.desktop/java.awt.Toolkit$ToolkitEventMulticaster.eventDispatched(Unknown Source)
	at java.desktop/java.awt.Toolkit.notifyAWTEventListeners(Unknown Source)
	at java.desktop/java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
	at java.desktop/java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
	at java.desktop/java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
	at java.base/java.security.AccessController.doPrivileged(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
So I get both are True so I would expect True, but nothing happens when I try to edit the cell. My onCellEdited is the supplied example of
def onCellEdited(self, rowIndex, colIndex, colName, oldValue, newValue):
	self.data = system.dataset.setValue(self.data, rowIndex, colIndex, newValue)
Can’t figure out what I am doing wrong here. Even if I change isCellEditable to just return True now I still get this error. Any ideas?
I figured out. I had put it into a scripting function and was calling it like
    PlantSetup.gui.isCellEditable(self, rowIndex, colIndex, colName, value)
But I needed
    return PlantSetup.gui.isCellEditable(self, rowIndex, colIndex, colName, value)
Too early on a Friday for me.
