I’ve recently upgrade Ignition to v8.1.3.
After the installation, I cannot launch designer launcher.
Found on forum
- Reducing the “Config\Designer memory” size to 512Ko ==> don’t change the problem.
- The execution of the launch command located in the “designerlauncher.log” in a CMD window returns me the folllowing error:
Exception in thread “AWT-EventQueue-0” java.lang.ArrayIndexOutOfBoundsException: Index 0 out of bounds for length 0
at com.inductiveautomation.ignition.common.util.gui.MultiLineStringUtil.toMultiLineByWord(MultiLineStringUtil.java:97)
at com.inductiveautomation.ignition.common.util.gui.MultiLineStringUtil.toMultiLineStringFormat(MultiLineStringUtil.java:59)
at com.inductiveautomation.ignition.common.util.gui.MultiLineStringUtil.toMultiLineStringFormat(MultiLineStringUtil.java:35)
at com.inductiveautomation.ignition.designer.gui.opencreate.ProjectListTable.setTableData(ProjectListTable.java:269)
at com.inductiveautomation.ignition.designer.gui.opencreate.ProjectListTable.(ProjectListTable.java:177)
at com.inductiveautomation.ignition.designer.gui.opencreate.ProjectPanel.(ProjectPanel.java:62)
at com.inductiveautomation.ignition.designer.ProjectDialog.(ProjectDialog.java:110)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.openProject(IgnitionDesigner.java:466)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.startup(IgnitionDesigner.java:451)
at com.inductiveautomation.ignition.designer.DesignerStartupHook.lambda$startup$0(DesignerStartupHook.java:336)
at java.desktop/java.awt.EventDispatchThread.run(Unknown Source)"
Any suggestion ?
