Hi Everyone,
I am trying to add and modify recipe parameters for the equipment using MES equipment manager. But it is not allowing me to edit the parameters. Getting the below error.
I have checked with the respective equipment tag in MES tag provider and no recipe is active for the equipment.
Can anyone suggest how to troubleshoot this?
If this is Sepasoft, you'll have better luck reaching out to their technical support. (Sepasoft is a separate company) Otherwise you may not get much help here unless someone else has had the same issue and happens to also run the Sepasoft MES. You may also check if there's any scripting on the code that is trying to modify that recipe and try to troubleshoot it if it's not a built in component of Sepasoft.
