Cannot print from pipeline block editor?
i have a script that i call from the Project Library in the Pipeline Block Editor. it has some system.perspective.print() calls. will that stop the execution of the script? i ask because when i directly use system.perspective.print() in the PBE itself it stops dead at that point.
Alarm pipelines have only gateway scope, not Perspective, so that group of functions doesn't exist. If you look at your logs, there's probably an error report that ".... doesn't have attribute perspective" or similar.
ah! that makes so much sense. thanks for explaining that. someday, they might actually let me finish my Ignition ramp and i can be a real boy! :smiley: @pturmel i am always grateful and intimidated by your comprehensive knowledge of this platform. thank you so much. :+1:
