Cannot read tag in S7-400 PLC
Bit of a strange situation, but Ignition is refusing to read a tag on a PLC that definitely exists. The full tag path is "[SIG01]DB5000,X0.0" (boolean tag).
Background:
I recently changed the structure of DB5000, after this Ignition refuses to read any tags inside of the DB. It always gives the error: [null, Bad("Bad_ConfigurationError: There is a problem with the configuration that affects the usefulness of the value."), Thu Apr 30 12:00:51 CEST 2026 (1777543251357)]. There are other tags also being read on the PLC (other DB's as well) and they work fine.
What I have tried:
  • Restarting the OPC-UA module
  • Removing the OPC Device and re-adding it (using same name)
  • Connecting to PLC via Kepware to confirm PLC side - This works
  • Added device 'test' in Ignition OPC using the same connection settings and adding the DB5000 tag - This works
  • Exporting tags as JSON and deleting them from the designer, then importing them again
  • Creating a seperate tag with the same DB5000 address
  • Deleting the DB from PLC and moving to DB5001 - This works (but we need this to be DB5000)
  • Going online and Deleting DB5000, then downloading it back to the PLC - This doesn't work
  • Exported all tags in the gateway and searcing for [SIG01]DB5000 tags to ensure there are no duplicate tags
Details:
  • Programmed in Simatic Manager
  • Connected using S7-400 driver
  • Port 102
  • CPU slot nr 3 (S7-400 CPU with CP card)
  • Ignition 8.1.37 (b2024013011)
  • Siemens Comfort Panel accessing the same tags
I am hoping there is some kind of cache that is causing this issue, a cache that can be wipe without causing issues to other devices since this is a production system.
Tag export:
  "name": "JDESI",
  "typeId": "JDESI",
  "tagType": "UdtInstance",
  "tags": [
      "name": "Control",
      "tagType": "Folder",
      "tags": [
          "name": "ic_ReqManual",
          "tagType": "AtomicTag"
          "name": "ic_Planned",
          "name": "ic_ReqAckAlarms",
          "name": "ic_ReqAuto",
          "name": "ic_ReqStop",
          "valueSource": "opc",
          "opcItemPath": "[SIG01]DB5000,X0.0",
          "dataType": "Boolean",
          "historyEnabled": false,
          "name": "ic_Interlock",
          "name": "ic_Warning",
          "name": "ic_ReqStart",
          "name": "ic_ReqReset",
      "name": "Status",
      "tags": [
          "opcItemPath": "[SIG01]Mx151.2",
          "name": "ps_Running",
          "name": "ps_Consumables",
          "name": "ps_Stopped",
          "opcItemPath": "[SIG01]Mx10000.6",
          "opcServer": "Ignition OPC UA Server",
          "name": "ps_Heartbeat",
          "name": "ps_Ready",
          "valueSource": "derived",
          "deriveExpressionGetter": "{source}\u003d\u0027Connected\u0027",
          "deriveExpressionSetter": "",
          "sourceTagPath": "[System]Gateway/Devices/SIG01/Status",
          "name": "ps_Connected",
          "name": "ps_Idle",
          "deriveExpressionGetter": "!{source}",
          "deriveExpressionSetter": "!{value}",
          "sourceTagPath": "[.]ps_ModeManual",
          "name": "ps_ModeAuto",
          "name": "ps_MaintAM",
          "name": "ps_LineDelay",
          "name": "ps_MaintPM",
          "opcItemPath": "[SIG01]DB5000,X0.1",
          "name": "ps_BypassInterlock",
          "opcItemPath": "[SIG01]Mx139.0",
          "name": "ps_ModeManual",
Do you have any other tags pointing within that DB, that may have been broken by the change that you made?
Currently, no. The DB shrank down from a list of tags to a remaining 2 tags (both booleans) with a few spare tags to fill the required word size. Thus, only the 2 tags that are giving an error still exist.
Is there an error in you Ignition Gateway logs like "Error reading S7ReadResponse. Error code NN"?
Hi Kevin,
I do not see any alarms, I also tried searching "SIG" in the logs but it comes back as empty.
You might need to let support take a look.
With the old Siemens driver, Bad_ConfigurationError only means two things:
  • invalid address (OPC Item Path) syntax
  • response from device with an error code (usually 0xFF illegal access)
I received a response from support: You do not have an active support plan on your current license, here is a quote for $20k to upgrade all licenses from 8.1 to 8.3 before we can support (this offcoarse does not yet include the 50% for our redundant licenses) - Yikes!
Seems odd since this doesn't look like normal behaviour from the Ignition OPC, for now I have changed the tag config from DB5000 to DB5001 and moved on.
