Cannot Save Project to Gateway
I am trying to save my project in I was able to save the project a few hours ago with no issues. I added a line of code and received an error saying the object is unscriptable. The designer has not been able to save the project since. I am getting the error below. The icon in the lower right corner says that the connection to the gateway is good. However, I cannot access the webpage to get the status of the system.
WARN [GatewayConnectionManager-PDT-Task-runner] Connection to Gateway lost, due to exception.
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:328)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:487)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:264)
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask$GatewayMessageTask.execute(PriviledgedDesignerTask.java:426)
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask$TaskThread.run(PriviledgedDesignerTask.java:328)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.socketRead(Unknown Source)
at java.net.SocketInputStream.read(Unknown Source)
at java.io.BufferedInputStream.fill(Unknown Source)
at java.io.BufferedInputStream.read1(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:407)
… 4 more
ERROR [IgnitionDesigner-AWT-EventQueue-2] Error reading updated project from Gateway.
… 4 more
INFO [Dev_ExhaustSCADA-PDT-Task-runner] Pausing scripts…
INFO [GatewayConnectionManager-PDT-Task-runner] Starting reconnect thread.
INFO [Dev_ExhaustSCADA-GatewayConnection-thread-1] Resuming scripts…
INFO [GatewayConnectionManager-GatewayConnection-thread-1] Stopping reconnect thread.
Support helped me find the issue. The Ignition Gateway service stopped running. After some digging, It was discovered that Java had been uninstalled on the server. I re-installed java and the Ignition Gateway service started running again. Thank you Marcus Bellamy for the help!
