rvaught
1
I’m able to manually write to this tag (by enabling the checkbox in pic) but have to enable the comm read/write option
However, I cannot write to it through scripting
path = '[default]G21/G21/MES/MES Control Hold'
system.tag.writeBlocking(path, True)
Does anyone know what I might be overlooking?
What version of Ignition?
writeBlocking expects a list of paths and values, not a single value.
system.tag.writeBlocking([path], [True])
- there’s a sneaky update at some point such that you can pass single values, but it’s still recommended to use lists all the time
rvaught
3
version 8.1.1.
I should also point out that it isn’t throwing any errors the way I have it?
Let me try the list of prarams. I’ll probably have to try it tomorrow but will get back to you here soon.
That change I mentioned happened in 8.1.3, so I suspect that’s the issue.
