Can't add new comment in comments panel
Good morning,
I’m trying to use the comments panel.
I created the table (name: Notes) in Microsoft SQL Server:
  • ID int (primary key)
  • note varchar(255)
  • whoid varchar(255)
  • tstamp datetime
  • attachment varbinary(MAX)
  • filename varchar(255)
  • sticky int
I copied the example " insertNote: using a single table" here Comments Panel - Ignition User Manual 7.9 - Ignition Documentation and I comment the MySql query and used the MSSQL Server query.
In the Data property of the comments panel I write this query
SELECT
	id,
	whoid,
	tstamp,
	note,
	filename,
	sticky
FROM
	notes
ORDER BY
	tstamp DESC
The result is that I’m able to read from the table (I write the values directly in it just to see if I could read them and it works. But I’m not able to write into the database.
There are not errors, but the output console report this messages:
08:31:26.878 [AWT-EventQueue-0] ERROR Vision.Components.PMICommentsPanel2 - Error invoking extension method.
org.python.core.PyException: Traceback (most recent call last):
  File "<extension-method insertNote>", line 43, in insertNote
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:362)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:258)
java.lang.Exception: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO Notes (note, whoid, tstamp, attachment, filename, sticky) VALUES (?, ?, CURRENT_TIMESTAMP, CONVERT(VARBINARY(MAX),?), ?, ?), [qdw, Manuel, , , false], , , false, false)
	at org.python.core.Py.JavaError(Py.java:552)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:538)
	at org.python.core.PyObject.__call__(PyObject.java:497)
	at org.python.core.PyObject.__call__(PyObject.java:501)
	at org.python.pycode._pyx18.insertNote$1(<extension-method insertNote>:43)
	at org.python.pycode._pyx18.call_function(<extension-method insertNote>)
	at org.python.core.PyTableCode.call(PyTableCode.java:171)
	at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
	at org.python.core.PyFunction.function___call__(PyFunction.java:471)
	at org.python.core.PyFunction.__call__(PyFunction.java:466)
	at org.python.core.PyFunction.__call__(PyFunction.java:456)
	at org.python.core.PyFunction.__call__(PyFunction.java:451)
	at com.inductiveautomation.vision.api.client.components.model.ExtensionFunction.invoke(ExtensionFunction.java:151)
	at com.inductiveautomation.factorypmi.application.components.PMICommentsPanel2.addNewNote(PMICommentsPanel2.java:248)
	at com.inductiveautomation.factorypmi.application.components.PMICommentsPanel2$AddNotePanel.actionPerformed(PMICommentsPanel2.java:672)
	at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runPrepUpdate(INSERT INTO Notes (note, whoid, tstamp, attachment, filename, sticky) VALUES (?, ?, CURRENT_TIMESTAMP, CONVERT(VARBINARY(MAX),?), ?, ?), [qdw, Manuel, , , false], , , false, false)
	... 56 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: SQL error for "INSERT INTO Notes (note, whoid, tstamp, attachment, filename, sticky) VALUES (?, ?, CURRENT_TIMESTAMP, CONVERT(VARBINARY(MAX),?), ?, ?)": Cannot insert the value NULL into column 'ID', table 'IgnitionDB.dbo.Notes'; column does not allow nulls. INSERT fails.
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:351)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:325)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:278)
	at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runPrepStmt(ClientDBUtilities.java:282)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runPrepUpdate(AbstractDBUtilities.java:256)
	... 54 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayResponse$GatewayThrowable: Cannot insert the value NULL into column 'ID', table 'IgnitionDB.dbo.Notes'; column does not allow nulls. INSERT fails.
	at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:262)
	at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1632)
	at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:602)
	at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:524)
	at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7375)
	at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:3200)
	at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:247)
	at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:222)
	at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeUpdate(SQLServerPreparedStatement.java:473)
	at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:136)
	at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeUpdate(SRConnectionWrapper.java:1016)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.RunPrepStmt.runUpdateQuery(RunPrepStmt.java:65)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractUpdateQuery.run(AbstractUpdateQuery.java:25)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.AbstractDBAction.invoke(AbstractDBAction.java:68)
	at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:405)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
	at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
	at org.eclipse.jetty.servlet.ServletHolder$NotAsyncServlet.service(ServletHolder.java:1391)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:760)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:547)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
	at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
	at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
	at org.eclipse.jetty.server.Server.handle(Server.java:500)
	at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383)
	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938)
	at java.lang.Thread.run(null)
Thank you very much for the help!
Look at the error message :
In my opinion, the ID column in your table should be auto_increment, since it is your primary key it can not be NULL so you should configure it with AUTO_INCREMENT.
Doing that will automatically assgn a distinct number to any new note you insert in your table
Thank you very much for the help, that was the problem!
I set it as AUTO_INCREMENT and it works.
I take this opportunity to ask help for another question that I can’t find in the forum.
Is normal that an user can’t delete a comment add by another user? I mean, the [delete] button is hide if I’ not logged as the user who create the comment.
Any way to manage it?
Thanks a lot againt!
Look at the canDelete extension function; you can provide your own logic there.
Thanks for the help, I had a look at the extension function but I didn't find what I was looking at.
Probably I'm not explaining well, but my problem is that if I'm not logged in as the user who create the that specific note, the Delete button is not visible.
I wonder if there's the possibility to permit at every user to delete every notes created, even by others users.
Yes, there is. Just return True in the canDelete extension function.
Ok perfect, it works! I was working on the deleteNote function instead canDelete.
Thank you for the help and have a nice day!
Copied all examples reference to the video from v7.9 and its not working but this error showing.
20:16:06.033 [AWT-EventQueue-0] ERROR Vision.Components.PMICommentsPanel2 - Error invoking extension method.
org.python.core.PyException: java.lang.NullPointerException: java.lang.NullPointerException
at org.python.core.Py.JavaError(Py.java:547)
at org.python.core.Py.JavaError(Py.java:538)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:192)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:208)
at org.python.core.PyObject.call(PyObject.java:461)
at org.python.core.PyObject.call(PyObject.java:465)
at org.python.pycode.pyx46.insertNote$1(:11)
at org.python.pycode.pyx46.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
(PyFunction.java:474)
at org.python.core.PyFunction.call(PyFunction.java:469)
at org.python.core.PyFunction.call(PyFunction.java:459)
at org.python.core.PyFunction.call(PyFunction.java:454)
at com.inductiveautomation.vision.api.client.components.model.ExtensionFunction.invoke(ExtensionFunction.java:152)
at com.inductiveautomation.factorypmi.application.components.PMICommentsPanel2.addNewNote(PMICommentsPanel2.java:244)
at com.inductiveautomation.factorypmi.application.components.PMICommentsPanel2$AddNotePanel.actionPerformed(PMICommentsPanel2.java:668)
Caused by: java.lang.NullPointerException: null
at java.base/java.io.File.(Unknown Source)
at com.inductiveautomation.ignition.common.script.builtin.FileUtilities.readFileAsBytes(FileUtilities.java:137)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:190)
... 49 common frames omitted
And also using the example from v8.1 gives me this error.
Parse error for extension function "insertNote" SyntaxError: (u"no viable alternative at character '\xa0'", ('', 22, 1, u'\t\xa0\n'))
