Can't connect to MySQL in the training class
I saw a few posts about this, but some were on Linux and some had a working connection that no longer worked. Mine has never worked.
I have installed and configured MySQL following the instruction on Inductive University. The database and Ignitions are installed on the same machine. I can access MySQL using the MySQL Workbench and I have created a ‘test’ schema. All the ports and setting are the default, but Ignition is not connecting to the database.
I’m not sure if this is related, but during the installation of MySQL, there was an option that was not covered in the video. It had something to do with authentication and there were two options, one was recommended and one was legacy. I choose the recommended (more secure) setting. I looked through the various options on the Workbench and did not find an obvious location to change the authentication mode to legacy if that’s the source of the issue.
Here is the error message:
org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (Unable to load authentication plugin ‘caching_sha2_password’.)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1225)
at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:880)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:242)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:196)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.lambda$newRetryRunnable$0(DatasourceManagerImpl.java:1004)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:565)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.sql.SQLException: Unable to load authentication plugin ‘caching_sha2_password’.
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:926)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:923)
at com.mysql.jdbc.MysqlIO.proceedHandshakeWithPluggableAuthentication(MysqlIO.java:1725)
at com.mysql.jdbc.MysqlIO.doHandshake(MysqlIO.java:1250)
at com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java:2465)
at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2498)
at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2283)
at com.mysql.jdbc.ConnectionImpl.(ConnectionImpl.java:822)
at com.mysql.jdbc.JDBC4Connection.(JDBC4Connection.java:47)
at sun.reflect.GeneratedConstructorAccessor58.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:404)
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:317)
at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:294)
at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1247)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1221)
… 12 more
7.9.10 (b2018112821)
Oracle Corporation 1.8.0_201
You will need to update the JDBC driver, or wait for 7.9.11 and do a fresh install (or, configure MySQL to allow the ‘legacy’ authentication scheme).
MySQL 8.0 changed things fairly significantly, and we have compatibility fixes in 7.9.9 and 7.9.10 as well, but we found some edge cases that aren’t completely squashed until 7.9.11.
Thank you for the reply.
I re-installed MySQL and chose the legacy option, but now I’m getting a different error. I’ve been able to connect to SQL Express, PostgreSQL, and Oracle Express, but MySQL has me stumped.
This is the new error message after choosing legacy authentication in MySQL:
org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (java.lang.ClassCastException: java.math.BigInteger cannot be cast to java.lang.Long)
Caused by: java.sql.SQLException: java.lang.ClassCastException: java.math.BigInteger cannot be cast to java.lang.Long
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1074)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:988)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:974)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:919)
at com.mysql.jdbc.ConnectionImpl.buildCollationMapping(ConnectionImpl.java:1062)
at com.mysql.jdbc.ConnectionImpl.initializePropsFromServer(ConnectionImpl.java:3556)
at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2513)
at sun.reflect.GeneratedConstructorAccessor49.newInstance(Unknown Source)
… 12 more
Caused by: java.lang.ClassCastException: java.math.BigInteger cannot be cast to java.lang.Long
at com.mysql.jdbc.ConnectionImpl.buildCollationMapping(ConnectionImpl.java:1007)
… 27 more
Are there instructions to update the JDBC driver? I’m completely new to Ignition.
Thank you for mentioning the updated JDBC driver. I was able to find the instruction and now the MySQL connection is valid :grinning:
https://support.inductiveautomation.com/index.php?/Knowledgebase/Article/View/125/0/connection-errors-when-configuring-mysql-80-database-in-ignition
