Can't convert Active, Unacknowledged to java.lang.String
I am getting this error when I try to get the value of current alarm status based on some filter using system.alarm.queryStatus function. Is there any way to convert Java string result into normal text/string?
Script Starts
props = [(“Group”, “=”, “Plant A”)]
state = [“ClearUnacked”, “ActiveUnacked”, “ActiveAcked”]
priority = [1,2,3,4]
lblState = “”
lblPriority = 0
numState = 0
c_alarms = system.alarm.queryStatus(any_properties = props, state = state,priority = ‘Critical’)
h_alarms = system.alarm.queryStatus(any_properties = props, state = state,priority = ‘High’)
m_alarms = system.alarm.queryStatus(any_properties = props, state = state,priority = ‘Medium’)
l_alarms = system.alarm.queryStatus(any_properties = props, state = state,priority = ‘Low’)
if len(m_alarms) > 0:
j=1
for m_alarm in m_alarms:
lblState = m_alarm.state
lblPriority = 2
break
event.source.parent.getComponent(‘lblState’).text = lblState
event.source.parent.getComponent(‘numlblPriority’).value = lblPriority
Script Ends
I am getting this error for lblState
Did you try to convert the AlarmState object to string str(malarm.state) as suggested by the Documentation
Hello Chi,
Thank you very much. It works now.
Also, you should put your code inside a preformatted text block so your code is readable
