Can't copy / paste color animation binding
Trying to do a copy binding / paste binding from a stroke color to a text foreground color.
Ignition 7.8.0
Java 1.8.0_65
Windows 7
Error:
Error during retrieval of clipboard data
Details:
java.io.NotSerializableException: com.inductiveautomation.factorypmi.application.components.util.ColorStateTable
at java.io.ObjectOutputStream.writeObject0(Unknown Source)
at java.io.ObjectOutputStream.defaultWriteFields(Unknown Source)
at java.io.ObjectOutputStream.writeSerialData(Unknown Source)
at java.io.ObjectOutputStream.writeOrdinaryObject(Unknown Source)
at java.io.ObjectOutputStream.writeObject(Unknown Source)
at sun.awt.datatransfer.TransferableProxy.getTransferData(Unknown Source)
at com.inductiveautomation.ignition.designer.util.ClipboardUtil.doPasteTransferableFromClipboard(ClipboardUtil.java:49)
at com.inductiveautomation.factorypmi.designer.property.propertytable.PropertyTablePanel$6.actionPerformed(PropertyTablePanel.java:276)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Ignition v7.8.0 (b2015101414)
Java: Oracle Corporation 1.8.0_65
This is still an issue in version 7.9.5… Is this a known issue?
Can you provide a project export or more concrete steps to replicate? I just set up a simple expression on a rectangle’s “Stroke Paint” property (toColor("255,0,0")) and copied that to a text field’s foreground color without issue.
Hi Paul,
On any colour property, configure a: tag, indirect tag, or property binding, where you have the table of values and corresponding colours.
If you then try copying this, you get the not serialisable error.
Perfect - that’s what I needed. I’ve filed an internal ticket for this; we should get to it in a future release of Ignition.
Awesome, cheers! This has been a small annoyance for a while
I Have a work around for this, instead of using Tag Binding, use the Indirect tag binding it will copy the color animation.
