Can't Install Ignition 8.1.15 on my Mac
Not sure if this is an ignition issue or an issue with my corp side. I get the following message when I doubule click on the ignition icon (.dmg installer)
“ignition-8.1.15-macOs-64-installer” can’t be opened because Apple cannot check it for malicious software.
This software needs to be updated. Contact the developer for more information.
This item is on the disk image “ignition-8.1.15-macOs-64-installer (1).dmg”. Chrome downloaded this disk image today at 1:05 PM."
You should be able to bypass this:
Our installers are not 'notarized' (Apple's parlance) because of some complications. For now, you have to jump through some hoops but you should be able to proceed without disabling Gatekeeper:
Comment from WillMT10 worked for me (Installing Ignition on macOS - Monterey - Gateway Installer doesn't launch - #3 by WillMT10),
cheers!!
