dcamp1
February 20, 2019, 8:40pm
1
I can’t seem to Launch a Client.
The Gateway is running on 192.168.0.2 (my home office PC) and my wifes pc on the same network 192.168.0.6.
The client launched always give me a “Time Out Error” when ran from her PC.
I have all the firewalls disable for a short period when testing.
Any clues as to what may be going on?
witman
February 20, 2019, 10:51pm
2
Can you access the Ignition server web page (http://192.168.0.2:8088/main/ in your case) from the PC you’re running the client launcher on?
dcamp1
February 20, 2019, 11:52pm
3
Yes, it works from my own PC.
craigb
February 21, 2019, 12:17am
4
You mention firewalls, did you disable the windows firewall on the server PC or allow port 8088 in?
witman
February 21, 2019, 1:37am
5
Can you access the Ignition server web page from your wife's PC?
dcamp1
February 21, 2019, 3:02am
6
I did disable all firewalls on her and my PC.
dcamp1
February 21, 2019, 3:04am
7
Not sure what you mean “Ignition Server Web Page” I can’t launch the client from her pc, but I have internet access and we share files between the 2 pc’s.
craigb
February 21, 2019, 9:39am
8
dcamp1
February 21, 2019, 12:41pm
9
No, it times out. I can’t figure out what is preventing me from making a connection.
Sounds exactly like what happens when the Windows firewall is enabled…
craigb
February 21, 2019, 1:18pm
11
I was just about to say take a second look at your firewalls on the server machine as that sounds like what the problem is.
dcamp1
February 21, 2019, 3:27pm
12
OK, I turned OFF “Windows Firewall” and everything worked. I run AVAST and had forgot about Windows Firewall.
Thanks for all the help.
craigb
February 21, 2019, 5:55pm
13
No need to fully turn off the firewall. Add port 8088 as a custom rule to allow incoming connections.
