I can login to designer and gateway, but not in client http://prntscr.com/kb4fco
GatewayException: Error authenticating.
caused by Exception: SQL exception during authentication
But DB is OK, and user is exist
How tom solve?
How tom solve?
Get the full details (click ‘full’ on the dialog) and paste it in here, ideally inside of three backticks:
some error message
here it is
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error authenticating.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:313)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:240)
at com.inductiveautomation.factorypmi.application.runtime.ClientGatewayConnection.doLogin(ClientGatewayConnection.java:90)
at com.inductiveautomation.ignition.client.gateway_interface.AbstractGatewayConnection.loginEncoded(AbstractGatewayConnection.java:530)
at com.inductiveautomation.ignition.client.gateway_interface.AbstractGatewayConnection.login(AbstractGatewayConnection.java:525)
at com.inductiveautomation.factorypmi.application.runtime.ClientPanel$LoginAction$LoginTask.run(ClientPanel.java:471)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.Exception: SQL exception during authentication
at com.inductiveautomation.ignition.gateway.authentication.impl.DatabaseExpertUserSource.authenticate(DatabaseExpertUserSource.java:135)
at com.inductiveautomation.ignition.gateway.authentication.UserSourceWrapper.authenticate(UserSourceWrapper.java:181)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.runLogin(Gateway.java:878)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:393)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:861)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:606)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(null)
Ignition v7.6.7 (b2014082615)
Java: Oracle Corporation 1.8.0_171
authentication need 3 things in the DB.
i think you missed at least 1 of these?
Is this a supported combination?
Hello,
I am having this same issue. I have tried to create a new user and assign it the appropriate roles with still no luck. The previous logins worked fine before. Below is the full details of the error:
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:327)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:301)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:258)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:884)
at com.inductiveautomation.factorypmi.application.runtime.ClientGatewayConnection.doLogin(ClientGatewayConnection.java:100)
at com.inductiveautomation.ignition.client.gateway_interface.AbstractGatewayConnection.login(AbstractGatewayConnection.java:900)
at com.inductiveautomation.factorypmi.application.runtime.ClientPanel$LoginAction$LoginTask.run(ClientPanel.java:519)
Caused by: com.inductiveautomation.ignition.gateway.servlets.gateway.functions.GatewayFunctionException: Error authenticating.
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.Login.client(Login.java:194)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(null)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:209)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:345)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:837)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1160)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1092)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
at org.eclipse.jetty.server.Server.handle(Server.java:518)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:308)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:244)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:246)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:156)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
Ignition v7.8.4 (b2016082217)
Java: Oracle Corporation 1.8.0_241
Thanks!
brian
