When I try to open a project in the designer I get the following error (and the designer fails to open):
ImportError: Error loading module compliance: Traceback (most recent call last):
File "module:shared.compliance", line 25, in
RuntimeError: maximum recursion depth exceeded
The compliance module was a script module in the shared library, but I deleted it and created a script package instead with the same name. After saving and closing the designer, I can't reopen it.
I still seem to be able to open a client window.
Is there any way I can modify the shared script modules without opening the designer?
Will restarting the gateway help?
How can I resolve this issue if I can't access the designer?
This is on Ignition 7.9.10
